I have a simple question, I bought some bushwacker style pocket flares to add to my 2016. now they match up perfectly but they sent bolts with nylon nuts (9) for each flare.
The problem is they mount so high up you cant access the back to put the nuts on. I know some are called rivet style which is the same thing. What did you guys use to attach them?
I was thinking rivets but I want all black to match the truck. I found these things called well nuts which is a rubber insert with threads on the end. As you tighten it it squezze's the rubber
forming a anchor into the fender. what I mean is you drill the hole then insert this rubber nut. it kinds looks like the plastic things you would use for a plaster or dry wall. when you put the screw in it
expands. I figured no rust, no steel to steel and being rubber no vibration noise. however its always good to check he and see what others did first so any input and photos would help a lot guys before
I try to do this. thanks....
