1 - 5 of 5 Posts
I'm considering adding a lift to my 2011 GMC Sierra 1500 6.2L 4wd Crew Cab. It currently has a 2.5" Top Gun Customz leveling kit, Rough Country 1.25" body lift, Bilsteins, and 33" Toyo MT. I know the leveling kit will need to be removed but I was thinking of leaving the body lift. I would prefer to remove the body lift but I don't know if I want to take the time to do it. I guess it will depend how everything will turn out because I want to do it right.
After doing some research, I think I want to run 35" Toyo MT and 20" wheels with a -44 offset, unless there is something wrong with this combination. In order to run this; I believe that could go with a FTS 7" lift with the adjustable 7-9 Bilsteins in the front, set at 9. I've read several recommendations for rear shocks including Bilsteins, Bilstein with res, and Fox 2.0.
I prefer the truck to sit level but wouldn't be opposed to a slight rake or very slight cali. Also, I don't mind trimming but I would prefer not to really hack into things. Maybe small NORCAL.
Will my proposed setup work, look good, and be reliable?
Any idea what kind of pricing am I looking at?
What front struts do you recommend and what setting and part number?
What rear shocks do you recommend and what part number?
I heard stacking rear blocks is not recommended and possibly dangerous. What is recommended to get the rear to sit level with the front with the Bilsteins set at 9? Add a leaf?
Should I take off the body lift?
How will the ride compare to stock?
Anything else that I missed?
35" Toyo MT and 20" wheels with a -44 offset will make your truck look amazing, I wish I had that set up. I have heard as well that stacking blocks is dangerous but some lifts say to do it anyway. You can add a 2inch add-a-leaf in the back to level out the trucks with the Bilsteins set at 9.
Sounds like it will ride great.
Another option is Firestone Airbags with the proper spacers could get you a bit more in the back, also nice to level with a load. Ive had mine in for 3 years now at 35psi and our winters hit -45c. never a problem. They keep a bit of stress off your leafs and mine will make a height difference of 4".
· Super Moderator, How-To Author, TOTM
With 35" tires, your likely gonna be in need of a gear swap front and rear. Work that into the budget. Unless you have taller ones already.
1 - 5 of 5 Posts
