So I've been trying to learn more about my truck (07 sierra 5.3l NNBS 68K miles) and how to use my scan tool( ELM327 wifi scanner with iOBD2 App).
I was looking through the stuff I can read and saw fuel trim and it seems mine is out of spec. I'm not getting any codes and I don't see any symptoms of a problem, but I'm wondering if this is something to be concerned with and what to do next. I recently got the truck and in the past week have replaced the evap vent solenoid/valve, fuel tank pressure sensor, plugs, and wires. I was having an issue with hard starting after it sat for a while and the fuel pressure was dropping slowly with the key on engine off and pressure is stable when running, but I ran seafoam through the tank and the vacuum line to clean out the engine and hopefully clear what I thought might be some leaky injectors. The starting problem seemed to go away for now(hopefully forever), but I haven't had the chance to check my fuel pressure again. Now all i'm seeing is this fuel trim data and wondering what could be wrong and how to go about getting it back to where it needs to be. The attached pictures are the fuel trim and the o2 sensor voltage after the truck has warmed up. Any help is greatly appreciated.
EDIT: Also recently cleaned the MAF and Throttle body
Is it wrong to assume that since both banks are reading the same the issue is likely something that effects all cylinders and not something like a bad injector?
