Can I use 5w-20 gas engine oil in a Duramax 3.0 diesel engine?
My .02 worth: Gas and Diesel engines are two totally different products! Diesels require a higher detergent factor and API rating for your particular engine. Is this your first diesel? I'm a retired driver/manager for Chevron and know what I'm talking about. There are other considerations as well, but those are the two main ones.Can you?
Sure you can use peanut oil if you want to.
But the engine isnt going to last long in that case, But diesel oil is slighly different from gas oil for a reason.
Why are you trying to ventrue out when you have a new truck that if you use the "wrong" oil they can void your warranty.
I find this highly suspicious.My mechanic told me this.
Use only what the manufacturer recommends And always the correct weight / viscosity.
A friend of mine was convinced upsold by an oil change company to use synthetic oil in a high mileage semi-synthetic engine.
It killed it... because it didn't cool it correctly... costing thousands to rebuild.
I use 5/30 euro diesel oil in mine love it.There are a few tube videos that state 5w30 is better. I will use 0w20 because of the warranty, but if GM approves 5w30 I will switch.
