Headlight Adjustment
1 reading
2.4K views 4 replies 5 participants last post by  bk2life
So I read somewhere to adjust your driver headlight for a 4 inch drop after 25 ft but your passenger headlight only for a 2 inch drop after 25 ft. Any ideas as to why this would be different? And would it be an issue if I adjusted to the same drop after 25 ft?
Driver side lower so you don't blind oncoming traffic. I ran mine both the same for a while but eventually raised the passenger side for the added sight distance
It is so you can see a little further down the shoulder of the road. See those reflecting eyeballs before they jump out in front of you.
I did the 4" and 2" thing on my '13 after installing Diode Dynamics low beam LED's. Never get flashed by oncoming drivers and have great beam patterns.
Projector lighting has this built in.
Here is a picture to show how the right isde is higher then the left.
Notice at 100 feet its about 3 feet high on right and a foot hig on left.
Very hard to blind someone with correctly adjusted projector lighting.
