1 - 11 of 11 Posts
So this morning i finally got around to installing belltech 2 inch drop shackles lift block was not removed. now i am getting Service traction control & service stabilitrack light.
has anybody gone through this?
Accidentally stretched/pinched/damaged one of the rear wheel speed sensor harness?
my Stabilitrack and traction is off. and i can't get them to turn back on, is it safe to drive like this? can i damage anything? i won't be able to take it in for service until friday.
Have you checked the harness going to each of the rear wheel speed sensors for obvious damage?
You'll be fine when my '11 did this I drove it from Miami Fl to south Georgia with no problems.
When I took it in to the dealer it ended up being a sensor and wiring harness under the dash close to the steering wheel.
Sent via my VZW Galaxy S3.
1 - 11 of 11 Posts
