1 - 7 of 7 Posts
I desperately need to know... Im in the process of purchasing a 2009 gmc sierra ext cab. It already has a 6 inch pro comp lift on it. With a 3 inch body lift will it clear 37x13.5x18r wheel and tire set up? I want to do this as cheap and as little cutting as possible. Hints? Tips? Suggestions?
jakehunk3611 said:
Dmanj said:
You'll likely be rubbing a good amount. This truck has an 8" CST lift on it with 37x13.5/20 and as it says in the thread he was only able to turn the wheel one full turn, then did the nor cal mod and was able to go lock to lock.
http://www.gmfullsize.com/forum/showthread.php?t=226571&highlight=cst+method
What is the nor cal mod?
There's a link on the 4th page of that thread that shows it. Also the truck in that thread is on 20x10's with a -24mm offset.
1 - 7 of 7 Posts
