1 - 8 of 8 Posts
Hi guys, new to the site and have been a proud 2000 chevy 2500 extended cab long bed owner for some time now. i was wondering if anyone out there knows how to squeeze a few more horse power out of this old engine. i'v already put a custom exhaust and air intake on her. any other suggestions ?
yeah i wasnt looking to spend that much, im gonna invest in one of those after a while. this chip from g force that is going around. anyone used/know anything about that? or if it is what is says?
You'd be better off saving the money for a better tune than just a generic chip
Banned
usually chips arent that good. they usually permanently mess with reading to the computer..this sometimes does more harm then good.
a tuner, better wires, plugs, CAI, Exhaust, Performance Y pipe, free flow cats, headers, FAST intake, larger throttle body, larger injectors, supercharger, better coils, better roller valvetrain, better oils (IE: Royal purple everything), stall torque converter, shift kit, lower gears......etc etc
hahaha.. those chips are garbage man.. snake oil.. don't waste your money... you know what they say about "if something sounds too good to be true..." ;)
to program/tune the truck correctly, you want to get a flash programmer, like the diablosport inTune or Trinity...
No replacement for displacement, well kind of...
There's boost, drivetrain gear ratios, bore/stroke and just flat-out drug-injection (N2O).
It all costs (big) money. While little bolt-on things like an air filter, muffler, and the relatively slight changes you can get from a tune are all easy enough to do and simple to do yourself, they all simply do not compare to what a supercharger, stroker, optimal axle gear ratio per trans and tire size, or N2O can do.
I'd start with a properly matched gear ratio to tire size. If you have something like a 3.07:1 ratio, you would enjoy going to 3.73:1 or 4.10:1- WAY more torque. I would not hesitate to go 4.10:1 on 265 (31-32") tires. I find the power with 265s, 3.73:1 gears and the 6L90 trans to be fine, but would have gotten 4.10:1 gears if the same truck with that was sitting at the dealer. $1000-1200 for a front and rear re-gear job with parts.
Supercharger- $7-8k, but would you like +100HP for starters?? That'll get you there.
Nitrous kit- $500-1000, but prepare to damage your engine and drivetrain. Not for constant use, just occasional blast-off.
Stroker- bored .30 over, new heads, lots of time, but you can hit 500hp out of the 6.0L.
..So save your $$$ for the things that REALY deliver performance. If the 6.0L is just not enough, there's always the 8.1L.
1 - 8 of 8 Posts
