How often to change fully synthetic engine oil?
23K views 155 replies 32 participants last post by  securityguy1
I bought my 2013 Silverado 2500 gasser this passed summer & one of the first things I did was get the oil changed with mobile1 full synthetic. It's been about 4,700 miles since then now. At what interval should I change the engine oil with it being fully synthetic? I know that the oil filter is a limiting factor... What's a good oil filter to use?? I'm going to start doing the oil changes myself. Thanks!
#86 ·
From every oil manufacturer that produces a PDS.
For example, let's use Pennzoil Platinum:
0W-20 - https://www.shell-livedocs.com/data/published/en-US/2e937649-ef26-473a-b37c-9dfb01188a94.pdf
Kinematic Viscosity - 40*C: 43.4 cSt
5W-30 - https://www.shell-livedocs.com/data/published/en-US/258dde47-b6ac-4f43-a960-5224b7ee00be.pdf
Kinematic Viscosity - 100*C: 9.8 cSt
So, when "cold" (still 40*C), 0W-20 is 4x thicker than the 5W-30 at hot or operating temperature. If, the 5W-30 being thicker caused problems, as you claim, the 0W-20 would cause problems at any stage of warming up except when fully up to operating temperature.
If you built race engines, as you so claimed, you should have at least a general idea of fluids and that they thicken as they're cold and they thin out as they heat up, for most fluids, especially automotive fluids. Whether it's engine oil, ATF, etc. The fact that you had to ask what someone was talking about in regards to cold oil/warm oil and how they compare tells us almost everything we need to know here.
#82 ·
Low speed pre ignition has been a problem with any engine even the Corvette engine That's why they're specking in oil without the low speed pre ignition issues it's not just for 4 cylinders never mind let's just drop this and everybody run what they want it's easier that way
Please don't take offense to this but can you read?
:unsure::unsure::unsure::unsure::unsure:
#76 ·
No call me out that's fine I have no issues with that but there's no way that a 30 weight oil is thinner than a zero weight oil it's impossible it's like a milkshake versus a glass of water it's not possible Read Rat 540s blog all the way through then you can call out whoever you want but you're wrong I hate to tell you there's no way a hot 30 weight is thinner than a zero weight oil. 5w30 flows slower than 0w20
#74 ·
Tires don't need air what are you talking about. It's all good I'm just going by what I know and what seems to work the best for me so everybody's going to have a different answer me I used to street race and build motors I'm on the side of rap 540 He's doing this for himself by himself with no one paying him and he's posting his results so I tend to believe him a lot more than any other people but that's just me you guys can believe what you want and not starting any shit
#120 ·
In a 2013 you can run what you want. Not the l83 ecotec. If you know what Noak and lspi mean then you would know
Not starting trouble bro. Just trying to make my truck live
To add some gas to this engine( guestion) On older trucks/ cars we would increase the oil viscosity, as it hit 100k mikes or so, going from 10/30 to say 10/40 or something like that. On the eco engine, this technique applies? Just wondering, old school here.
#73 ·
So, this is what we call an appeal to authority fallacy argument. The engineers are not designing the vehicle to last forever, they're designing it to get out of the factory warranty period without major issue and cost to the manufacturer.
Secondly, look up the viscosity of 0W-20 and even just a 5W-30. 0W-20 is thicker cold than the 5W-30 is at operating temperature ((to the multitude of 4-6x as thick) (most 0W-20's run in the 50s-60s when cold and most 5W-30's run 9-12s at 100*C operating temp)). If, as you so wrongly claim, that just because a 5W-30 oil was thicker, it would automatically cause AFM lifter issues, the engine would not be able to run when cold or in cold temperatures with a 0W-20 oil. So this completely negates your argument that you have to use 0W-20 or else AFM lifter issues will happen, just based upon viscosity. Now, with that said, there is diminishing returns and eventually you would find a fluid with a thick viscosity that it would cause issues but that simply won't happen with a 5W-30 or even a xW-40 oil.
Your 18 runs like a swiss watch just like someone elses '14-current would run like a swiss watch with 5W-30 or xW-40 oil because they're simply not thick enough to cause issues. Your anecdotal sample size of 1 does nothing in the grand scheme of all things relating to statistics and stastistical analysis of a gigantic group.
In conclusion, I don't really want to call you out being wrong to your face in front of the entire forum but what you're saying is completely and utterly incorrect.
#59 ·
Back in the day, my friend, Nino Consolo, a nice Italian guy from Bay Ridge, Brooklyn, whose family had mafioso connections had a 71 Grand Prix SJ 455 HO. The car ran in the 10s. He never changed the oil or filter. One day the oil filter exploded. He immediately shut it down, installed a new filter, added oil, and went right back to what he was doing that day.
