How often to change fully synthetic engine oil?
23K views 155 replies 32 participants last post by  securityguy1
I bought my 2013 Silverado 2500 gasser this passed summer & one of the first things I did was get the oil changed with mobile1 full synthetic. It's been about 4,700 miles since then now. At what interval should I change the engine oil with it being fully synthetic? I know that the oil filter is a limiting factor... What's a good oil filter to use?? I'm going to start doing the oil changes myself. Thanks!
i have a 2016 2500hd with the 6.0. go to bob is the oil guy forum and you'll learn more than you ever wanted to know. bottom line you are definitely safe going by the OLM and can usually get away with using the same filter for 2 oil changes.
personally i cant see bothering to crawl under the truck and not swap the filter, so i change them both on the first convenient day when the OLM gets below 10%. delco filter and the cheapest dexos 5w-30 full syn i can find, used to be supertech but lately has been quaker state high mileage.
Oil is cheap. Engine rebuilds ain't. I can't be screwing around with oil analysis. That's the only true way to know.
Everybody is claiming all of this high mileage intervals and extended life oil and maintenence free cars, and all of this other horse manure they're spouting.
Nobody ever said F all about extended life oil filters, did they?
If modern oils perform better, then that means that they clean the engine better. And that means that modern oil is carrying more junk in it. Which means the filter is working harder, thereby collecting more trash.
Logic dictates that, if anything, you should change these super oils more frequently. Or at least, change your filter more often.
Personally, I don't over think it. 3k miles, it gets changed. And it looks plenty dirty every time.
I've seen inside numerous engines where the vehicle manufacturer and the oil jug both say you can go for this crazy extended interval, and the lie detector determined that both the vehicle manufacturer and the oil company are excessively full of S.
Dealership service history states this vehicle has come to this shop every X miles and gotten the recommended service religiously. The owner of the vehicle has carefully followed OEM and oil brand recommendations. The engineers have sworn that you can go this many miles, no problem.
Well if they're so smart, then why is this top end completely caked in sludge? Why is that crank turning blue gold and purple with heat caused by plugged oil passages caused by sludge created by extended intervals?
I'm not convinced by the slick marketing, but I am convinced by what I've seen inside plenty of engines.
Suit yourself. Carefully follow the owner's manual. Listen to Pennzoil or Mobil or pick your poison telling you that it's safe to go 5, 6, 8, 10k miles or whatever. I'm perfectly happy to charge you money to fix it.
>>The reader will note that my normal monotone has changed to one of bitterness and sarcasm. It angers me to see my customers getting screwed by following poor advice given by the OEM in order to boost sales.
#43 ·
...Oil is cheap. Engine rebuilds ain't...Nobody ever said F all about extended life oil filters, did they?...If modern oils perform better, then that means that they clean the engine better. And that means that modern oil is carrying more junk in it. Which means the filter is working harder, thereby collecting more trash. Logic dictates that, if anything, you should change these super oils more frequently.
If I could have said that better I would have...but I couldn't, so I quoted the author.
