I was looking for a way to disable the DRL and Autolights only for when going hunting so when i enter the bush or field my lights are not lighting up the whole woods. I coulnd't really find any real "how to" so i decided to write one up.
Skill - Anyone with a pulse
Time - 10 -30 mins
Tools - 7mm Socket Deep or with Extension and Rachet
- Trim Pry Tool/Flat Screw Driver
- (2) 5W 1.8K resistors ( Radioshack or The Source in Canada Has Multi Pack For $6.99 CDN)
- 5/8" x 3" Dual Wall Shrink Tube or Electrical Tape
- Optional Side Cutters
Auto - Lights Disable
First step is to remove the drivers side pillar cover, remove the cap and behind it is a 7mm bolt, after removing that there is one clip 2/3 of the way down, be careful not to brake it, mine kinda broke a bit but it still sits well
Then lift the front cover of the dash off, its held in place by 5 body clips really easy to come out with a flat pry tool or trim removal tools
Then you twist the sensor counter clockwise to unlock it, unclip the sensor and with the plug facing you and the tab to the top, insert the two 5w 1.8K resistors vertically
you can cut the tabs off to make it easier to install the shrink tube or you can leave them upto you. You can also use electrical tape if you ever want to go back to stock, i dont plan on it so i choose to have mine well secured with the shrink tube, worst case you depin the wires and get a new connector
Reinstall dash front cover
Reinstall pillar cover
Day Time Running Lights Disable
Remove fuse 32 and 34
Test operation of lights - MAKE SURE YOU APPLY PARKING BRAKE, CHOCK ATLEAST A WHEEL OR HAVE SOMEONE HELP
Time - 10 -30 mins
