I was wondering if there were any common issues like mine out there. My truck is a 2004 silverado 2500hd extended cab with a 6.0l. The truck has had a body control module code since I got it back in July. I forgot what the code was exactly but it had to do with not communicating to the BCM i believe. Never been an issue all ive noticed is that it typically wont do a bulb check until the truck is started. Well tonight i was driving home from work and I have a check engine light, abs light and brake light on. That is normal for me because of an o2 sensor and me pulling the abs fuse. I was driving and out of nowhere the abs and brake light turned off completely and so did my odometer. I didnt think much of it at the time but a few minutes later I went to make a turn. I put my blinker on and instead my 4 ways came on. I put the blinker back to rest and tried it again and it worked fine. But then my entire dash did a bulb check and the lights came back along with the odometer coming on as if i just started it saying "driver 2" shortly after i went to make another turn and the same issue happened. The 4 ways came on them a random bulb check along with the odometer acting up. I have yet to scan the truck since it happened.
