So the other day I got in my truck and the A/C blower would not come on. After fiddling with the controls a bit I gave up and rolled the windows down. About five minutes later it was eating at me so I switched the control from off to max and the fan kicked on like it was supposed to and was blowing cold air. Since then, every once in a while I notice that the fan doesn't come on when I start the truck, or if it does it's very weak, so I crank it to max, the fan blows noticeably, then I turn it down to a more reasonable setting.
Since I've had this truck, the low setting on the fan has always been pretty pathetic, but I had nothing else to go off of, so I was like, whatever, and let it roll. Now that I'm having this intermittent "no blow" from the fan, I'm determined to find the root of the issue and correct it.
I posted in another thread, but nobody replied, so I figured I'd start a new one. I saw where the blower fan resistor can go bad, so I've got one of those on the way from Amazon.com. I figured with 100k on the truck, it can't hurt to change out a $30 part anyway. Are there any other parts that I should be looking at as possible culprits? Thanks for your input.
