I've had my '00 Silverado 1500 4.8 RCLB 2wd for a little over a year now. It's been a great truck with no major issues until now. Among other unrelated problems (typical GM abs light, brake light, fuel sending unit showing low fuel, oil pressure sensor) I now have an intermittent hard start/start & stall issue with the weather getting colder. I didn't have any of these issues last winter, the truck always started up and ran like a champ. No issues in the summer either.
When I start it up cold in the morning it will sit there and crank for 2-3 key cycles without even trying to start. Eventually after about 3 primes of the fuel pump it will run no problem. After driving it and warming it up I shut it off and leave it for a few minutes, then come back and it will start up and run for a second, then stall. It does this 5-10 times before it will finally run. When it does run it idles smooth as glass and has plenty of power. We can rule out the security chip key as my truck is a base model that doesn't have that "feature".
The fuel pump was new a couple of years ago but the fuel pressure regulator has never been touched. No fuel comes squirting out of the vacuum line when I take it off the FPR so the seals inside are good, I'm stumped. any ideas?
