keep blowing fuse
9.3K views 9 replies 2 participants last post by  ASTE25
2006 silverado 4x4 6.0L the fuse for dash lights keep blowing, it is the TBC 2A 15A, it goes to the BCM Body Control Module do i just replace this module?
It could be a module, but the safest way is to actually check the wiring and make sure it is not shorted to ground. It could be any component on that circuit as well.
In that case, check the wiring harness to make sure it is not damaged. If the only thing on the circuit is the module, and the wires are not damaged, it's a safe bet it's the module itself.
Does it not have any wires coming from the BCM and going to other components? If it does, then it could be a component that is attached to the BCM.
