1 - 3 of 3 Posts
AUXITO Auto Light | Ahead of the Ultimate Choice
Hey, guys.
AUXITO has customized the kits for the 2014-2015 Chevrolet Silverado 1500 and they install without flickering or not fitting. They are plug-and-play.
Package Included:
2 Y13 Series 9005 LED headlight bulbs (High Beam)
2 Y13 Series H11 LED headlight bulbs (Low Beam)
2 I9 Series 5202 LED bulbs (Fog Lights)
2 T15 White (Back up Lights)
4 7443 Amber/White (Front Turn Signal Lights)
4 load resistors (For Front Turn Signal Lights)
2 T10 White (License Plate Lights)
The following are reference pictures of AUXITO LEDs.
High beam: 9005, 360-Degree illumination, Perfect Beam Pattern.
Automotive lighting Automotive tire Automotive design Office supplies Font
Low beam: H11, CAN-BUS Error-free, Plug & Play Installation.
Automotive tire Tire Office supplies Automotive lighting Font
Fog light: 5202, the IP65 waterproof can be applied to foggy, rainy, snowy, dusty all weather conditions.
Automotive parking light Tire Vehicle Automotive tire Car
Front turn signal light: 7443, the switchback turn signal flashes 'amber-off-amber-off' instead of 'amber-white-amber-white', much easier to be seen. Fit for dual filament socket. They will light up with white color as the low-filament running light/parking light, and switch to bright amber any time when you hit the turn signal.
Automotive parking light Automotive tire Hood Camera accessory Automotive lighting
Backup light: 921, built-in smart IC driver ensures constant current, no radio interference, instant-on capability with zero warm-up time.
Automotive lighting Light Headlamp Automotive tire Gas
License plate light: 194, LED bulbs are special with led chips to cover design, protecting led chips and components, safer and more good-looking, emitting a more rounded and fuller light.
Product Rectangle Triangle Font Material property
In addition to the above-mentioned, we also have the kits for the 2008-2021 Chevrolet Silverado 1500 2500 3500
Will these fit the Recon OLED Halo aftermarket housing units???
Did you modify the assembly? If the assembly is modified, the factory halogen light bulbs and the size after modification may be different, but it is possible to replace the LEDs.
1 - 3 of 3 Posts
