I have a '12 crew cab LT1 silverado, I have foot lighting installed in all four doors, they light up the ground when the door is open they have one cree led light bulb in them each, so 4 bulbs total. I had my installer add one diode wire to the door trigger wiring so they turn on when the door is open, & had him install a kill switch so I can keep them off if needed. The power for the lights is coming directly off the battery terminal with a fuse near the batt in that wire. This all seemed to work fine for 2 days before i left town for 2 weeks.
When i came home i had 2 strips of led lighting in stalled in the bed (just under the bed rails) with a motion switch attached to the tail gate so they come on when it is opened. The strips have 3 led bulbs each, also had a 3 way switch installed with in this system the 3 positions being on, off, or motion switch. The power & ground for this system is completely independent & not spliced into any existing elec equipment or wiring, the power also comes directly off the batt with a fuse.
When I picked up the truck after the second install the 'hood open' light was on, dome lights were acting funny, turn signals hazard lights in op, auto day running headlights won't turn off, no brights, & radio had constant power. Took it to the dealership, they swapped out the bcm & the door lock module, everything went back to normal for a few days then same symptoms. Had all my aftermarket lights disconnected, took it back to the dealer had another bcm replaced, then had the lights hooked back up, same problem, a few days later the bcm went out again. Now have had all aftermaket lights disconnected again & wires hidden, getting another bcm tomorrow, the dealer requested i remove all aftermarket wiring.
I would really like to get all the lights working with out frying my bcm every 3 to 4 days, but am also very concerned about upgrading anything electrical seeing as my current elec system can't even handle a total of 10 small led bulbs pulling a very small amount of power.
Any Advice?
Any Advice?
