EKinMN
the truck showing on you Big frog,,,,,, does that truck have the 2 inch lift with 2" lift on it?? also what kind did you choose, and did you change out the shocks to anything special I mean struts? And the 40 k after installing the 2" lift,, were the boots new at time of installing lift?? If not whats the total on the boots before installing the 2" lift.....
I agree the 1/2" more beyond the 2" drastically plays with the lower control arm radius more than the total from original ride height meaning close to zero degree. on alignment,, shooting the beams,,, it's only about 1.5 degree change from original ride height through the arc up to the 2 inch unsprung height as in a bump causing it, but creating the 2" lift now you're at 1.5 degree into the arc,,, watching the alignment beam then add that 1/2 degree more,,, the arc angle, or what we used to call the "Ackerman" effect changes 7.75 degrees negative,,, before you driving over that same 2 inch bump that at original ride height only changed the arc angle 1.5 degrees from zero. hope that makes sense.
When lifting the truck on a hoist, and watching the front tires un springing as the truck moves off the ground,, watch the tires,,, go through this arc,,, or the "Ackerman" effect. changing camber caster angles will not change this arc either... yes to save the boots on this angle before bumps,, you can drop the diff as everyone says here,,, but that arc does not get to zero,, and still will create that extra stress and heat at all times even normal mini bumps down the road are amplified with this where zero to 1.5 degrees is now at 1.5neg to 7.75 neg only on a 2" bump. only way to effect this angle/arc,, is to either drop down upper control arms to what ever level changes the arc back to zero so you're in the middle of this arc/"ackerman effect" for impact and unsprunk bumps.... or a more expensive lift kit that has longer upper control arms for this minimal 2.5 inch lift. just dropping the diff to establish drive line angle doesnt fix it all.... talk to any old alignment guy from the days when almost all 11 angles were adjustable. or a oval race guy... they still play with these angles.. and it's all guess work too,, unless theres a lift kit out there that has it figured out yet..
Long winded hey?
EKinMN
you take very very great care in your equipment, and high pride too,,, I can only expect you should expect the least amount of premature wear on these boots,, let alone any other aspect of your baby there... I've been following some of your advice here too..... good job on all your writeups I've had the pleasure of reading....
