A little help please. I am replacing the rear brakes, calipers, rotors on my 2005 GMC 3500 sierra 4X4. It is a dual wheel 3 yard dump truck. The caliper got stuck on the left rear while I was plowing and fried the rotor. I have removed all of the essentials; wheel, caliper, caliper bracket, axle cap bolts, axle, clip ring, square "key", and the bearing keeper nut. All that is left is the hub/rotor. It is my understanding that this should slide off, so I can replace the rotor. It is loose, but as I look inside the axle chamber, I see the bearings and they do not seem to want to come out. Almost like the bearings are holding the hub/rotor in place. What am I doing wrong? Thanks in advance for any input.
fletcher31
fletcher31
