I have a 2016 Silverado with 1000 miles on it. Was running great until I stood on the gas at a green light (only got the rpm's up to about 4200). There has been a noticeable loss of power across the board ever since. The truck used to set you back in the seat a little bit when punching the accelerator - now not even close.
Going up hills is a struggle - I can hear the engine bog down when pressing accelerator to maintain speed - eventually the rpm's jump up once the accelerator is pressed far enough.
Same when accelerating through a turn - let of the gas going into the turn, nothing but weak throttle response when accelerating through the turn.
I've had it in to the dealer three times and every time they tell me a technician drove it and could not find a problem. They won't put much effort in since it isn't throwing any codes - but having put the first 1000 miles on it, I can tell there's a problem.
What can cause an issue like this and not throw any codes?
