1 - 6 of 6 Posts
I saw something here but can't find it again, it was about changing the oil pump and pick up tube o ring by going through the timing chain cover. Any help would be appreciated and any how to videos you could suggest. Sounds easier than removing the pan???
Thanks
Typically low oil pressure is the sensor, or the engine worn out meaning the clearances are opened up on the bearings; not so common that the issue is in the pump/pickup. Is your pressure gauge reading any pressure at all?
I don't know about the LS 4.8&5.3 vortecs, but you may have to drop the pan some to get the cover off anyways if you do what you're thinking of
Great video, thanks! It's my son in laws truck and he is going to replace the sending unit tonight, just looking for what to do next if that doesn't fix the problem. He starts it and oil pressure is 40 but shortly drops to 0 and the alarm sounds. He can let it sit a bit and start it again and the same thing happens. He said there is no noise of any kind so hoping its just the sending unit.
1 - 6 of 6 Posts
