I have an 05 Z71 Silverado with 138,000 miles on it. It developed a rhythmic noise at idle, sort of a low pitch squeal. It sounded like it was coming from around the serpentine belt area but I couldn't find it. I took it to the mechanic who first thought it was the idler pulley, but when they pulled the serpentine belt off they ran it again and it was still there. They think it is the main bearing starting to give out and recommended an engine swap. Total for a used (not rebuilt, but <100k mi) is $3300 with labor.
Is there anything else you recommend checking before getting an engine swap? Any advice on getting a used engine vs other options?
The truck is only worth about $8k on KBB, so I'm debating on how much I should put into it and how much life I might expect out of it.
