Hello friends, I'm new here and this is my first post.
I literally made this account to get some insight and hopefully some help for myself and my journeyman mechanic friend on my PITA truck. My truck is a 2006 Sierra 1500 SLT 5.3L "T" engine with a nice list of mild upgrades.
I recently just did Spark plugs (NGK) Spark plug wires (NGK) new GM knock sensors, GM intake manifold gaskets. Now the long story short... I was out elk hunting... Truck went into limp mode in a snow infested field (I live in Saskatchewan, Canada) in literally the middle of no were. Had to get my buddy to tow me, my trailer, quad, and elk out. Had the truck flat decked to a mechanic shop that tried to fix it (they did an O2 sensor, new plugs, new wires. They were a bunch of brain dead idiots to say the least. **So to get to the point the truck had a nasty misfire that they said cleaned up with a tune up. Truck drove good. Only issue was when cold, it would shake and shutter a bit. But when warmed up it would run like a top. Had the knock sensors done at my buddies shop. Truck still shuttered. Took it back and we looked at it. Took the intake manifold off checked to see if it was warped or not... It was with in spec. Changed out to the new updated GM intake manifold gaskets. Put it all together and it still shuttered and idled goofy when cold. We tested everything... fuel pressure, compression, swapped injectors, swapped coil packs ... Put a misfire counter on #8 and its misfiring when cold, but clears up when warm (none of the swaps changed anything) We did a leak down test. DING! #8 lifter is collapsed YES! well... lets double check it to make sure... Well it passed no collapsed lifter...
What in sweet baby zombie jesus's name is going on? Please help... Will send elk meat... and beer... and a hardy hand shake!
(ps... sorry for the ramble thats probably mixed up)
