41 - 50 of 50 Posts
Discussion Starter · #42 ·
It's alive! Put a shitload of hours in on it over the last week+, cause I'm getting kicked off my old man's lift for his dumb new Mopars. A lot of the final little details turned out really well. It's uncanny how well a truck fuse block and PCM fit a Beretta. haha And my modified headers miraculously can be removed from the top side, and still have access to the starter and steering shaft.
The fuel tank and a couple other things are sloppy cobbed together at the moment, so it's still not road worthy. But it runs and will be making tire smoke by this weekend. More detailed video coming soon, obviously.
Nothing like a man with desire, dreams, and talent!
Let me know when you need a vacation and you can come over and help me with my projects :)
Discussion Starter · #45 ·
haha I don't even have enough time to get all my stuff done!
Here's the thrash video. And the next one will show smoke!
After I got it fired, I discovered the clutch wouldn't fully disengage. 6.1:1 Wilwood pedals and 3/4 bore master should have been ok considering the 4th gens had 6:1 pedals and 3/4 master cyl...but apparently McLeod and Spec clutches both need a 7/8 master. Fittingly enough, my used Spec clutch did come with a 7/8 master. Probably should have done some homework on that then. But it was a universal style Tilton that fit the Wilwood pedals just like the Afcos I'm running.
It was sketchy AF on the initial test drive! My "oh how bad can it be" bumpsteer was really bad, so I stole a couple 5/8 heims from the Camaro and dialed it in a lot better. I also adjusted my pinion angle (cause I had forgotten) and made a tweak to the driver rear lower control arm length. Should be a marked improvement on the next test drive.
Discussion Starter · #49 ·
Coilovers for the front in the works! No pillowball mounts and nasty NVH though...I'm using a DIY non-adjustable strut mount with 2 more degrees caster built in. And it has rubber isolators for the spring and the strut stem. My mock up shows it working beautifully. The picture on the ground is in the center of the adjustment, so I can go up or down about 2 inch from there. More info to come once I finish it up and make a video.
You can also see another change if you look close, but I'm not gonna spill the beans on that just yet.
Discussion Starter · #50 ·
Got the coilovers done and the video up.
Alex cut some plates on his plasma table from a PDF I designed in Adobe Illustrator (poor man's CAD). haha. I moved the pivot back for more caster and isolated with rubber so the NVH should be fine. Using 200lb springs instead of the factory 145lb, and I had to cut the perch off completely. I also cut the steering arm down so I can use it as a mount to make the 33mm Blazer swaybar direct acting.
Now the front looks so good I'm hacking up the rear unibody frame to get the ass down to match. On the next episode of...Gearhead dezign. haha
41 - 50 of 50 Posts
