I just finished changing the coolant on my 2011 5.3. Only took me 8 hours! First time.
Here's what I did; is this correct?
1. I drained the coolant from the bottom hose, but I used the end that attaches to the engine, not the end that attaches to the radiator. It was easier to get on and off.
2. I filled the system with hose water and drove it with the heater on. I let it cool, then drained it. I disconnected the top hose at the radiator and the bottom hose from the engine and used the garden hose to flush out the radiator. The water was clear.
3. I filled the system with distilled water. I used 2 gallons and the system was full. I drove it with the heater on, let it cool, then drained it. I repeated this step. Water was very, very light orange.
4. I filled it with Dexcool. I bought the premixed 50/50. I used a little less than 2 gallons. I thought the system takes about 4 gallons?
5. I will check the coolant after the truck sits overnight and cools all the way down and see if it needs more.
My original help post is here, but I thought I'd start a new one since the other one was getting kinda long.
coolant flush
Thanks!
coolant flush
Thanks!
