So my truck which has been a disaster of a purchase since selling my Ram. It has had never ending repairs in less than a year and just had its most recent expensive repair, a broken leaf spring. This is after re doing the entire rear end the month prior. And now my well waxed and taken care of clear coat falling off of the truck due to GM's horrible paint job.
It has a 6inch fabtech lift with the dual front shock mounts, and fabtech traction bars.
So I took it to a local spring shop and they added 3 springs to each side to take the tension off the rear end hopefully making it last longer and replaced the cracked leaf.
I could have had them just fix the one leaf but decided to spend more and do it right being that I'm so upside down now with constant repair bills on this pos that I'll probably have to drive it for 400k miles.
They told me it wouldn't need aligned. But now the truck is turning hard left especially when braking and has this horrible very load groaning creaking noise in the front end on acceleration and stop. Does it every single time you stop or take off. They only worked on the rear leafs did nothing to the front.
It doesn't do it side to so it's quiet on turns. Its when the weight of the vehicle either swings forward or back based on starting or stopping. Sounds like some old horror movie when they open the door and it does that long creaking noise.
I tried lubing everything which did nothing. Next step I was planning on re torquing the entire lift basically. Where are likely spots for the noise if its a front to back momentum noise?
