1 - 20 of 30 Posts
After removing the plastic belt guard and damaging the plastics of the front bumper in the sand dunes a couple of weeks ago I've decided to replace the lower plastics with a metal bar and integrated sump guard
The plan is to remove the lower plastic from the front if my 2010 silverado and cut the side plastics in line with the bottom of the metal chromed section
Icon are going to custom fabricate a bumper for me. A tube running below the front of the middle metal section will continue the line round below each of the side trimmed plastics and the sum guard will run from this down to the bottom of the engine
It will attach into the bolts of the towing points, the bar the top of the plastic guard attached to and to where the bottom attached
The front towing hooks will be clear
It will be interesting to see how it turns out
It's a reasonably cheap option for an offroad solution and reasonably light too
Also be a lot less aggressive and obvious than some offroad metal bumpers
There are a few advantages
I've already removed the lower air dam so this will remove 6 inches of plastic below the hooks
The metal tube will start an additional 2 inches higher
It should be strong enough to hit the sand without damage unlike the plastic
It should provide a smooth surface that will slide on the sand when it hits reducing stress on everything
With a 2 inch front levelling lift that's 8 to 10 inches of extra clearance at the front over standard.
Discussion Starter · #8 ·
Will get things measured up on Saturday. Should be fitted by the middle of next week
Will definitely post pics. I haven't seen an offroad bumper conversion done in this way despite doing a lot if searches. All of the images I've seen are complete replacements
Discussion Starter · #11 ·
Been doing a bit of googling and it's looking like a winch either needs more room than is provided behind the metal part of the standard bumper. This seems to be typically solved by a full metal offroad bumper which is something I'm trying to avoid (for cost, weight and look reasons)
Mounting options seem to be either via an external mount or if hidden then slung low behind the lower plastics that I'm removing
Discussion Starter · #17 ·
Spoke to the guy who is going to do the bumper today. An integrated hidden winch mount plate is definitely an option for about $120 extra.
My concern for a hidden winch is it will be quite inaccessible. The environment here is pretty brutal on equipment like winches. I don't know much about this kind of stuff. Someone mentioned a hitch mounted winch option. Wondering is this might be a better option
Truck is booked in for Monday, will be in for about 3 days
Discussion Starter · #18 ·
So a quick update
Dropped the truck off this morning. It should be ready on Wednesday.
Decided not to get a hidden winch mount built in. I think the the location would make the winch very difficult if not impossible to access for maintenance which is not good in as dusty as environment as we have here. Plus having a lump of weight like a winch right out the front would make the nose dive even more (if thats possible on such a big heavy lump of a vehicle anyway!!). The extra $120 didnt add up
If I need a winch in the future I'll consider a hitch mounted unit.
1 - 20 of 30 Posts
