Note - Full synthetic is not required...the only requirement is the oil meet dexos1 or equivalent.
DATE 05/11/2015
SUBJECT The Engine Oil Capacity - with Oil Filter Has Changed
MODELS 2014 - 2015 Cadillac Escalade, Escalade ESV, Chevrolet Tahoe, Suburban, Silverado, GMC Yukon, Sierra, Denali Equipped with GEN V V8 Engines - 5.3L RPO L83, 5.3L RPO L8B or 6.2L RPO L86
TO Cadillac, Chevrolet and GMC Dealers
ATTN Parts and Service Director, Parts Manager, Parts Counter Personnel, Service Advisor, Service Manager, Service Technician, and Fleet and Commercial Managers
The Engine Oil Capacity - with Oil Filter for all GEN V, V8 5.3L and 6.2L engines has been reduced from 8.5 quarts to 8.0 quarts.
This change has been implemented in SI and will be reflected in future Owner Manuals.
Thank you for your cooperation.
END OF MESSAGE
GM CUSTOMER CARE & AFTERSALES
Document ID: 3998244
#PIP5231A: Concern of engine oil dipstick indicating an overfill - (Oct 9, 2014)
Subject: Concern of engine oil dipstick indicating an overfill
Models: 2015 Cadillac Escalade 2014-2015 Chevrolet Silverado 1500 Suburban, Tahoe 2014-2015 GMC Sierra 1500 Yukon with engines 5.3L, 6.2L RPO's L83, L86
This PI was superseded to update Recommendation/Instructions. Please discard PIP5231.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
The Engine oil dipstick indicates an overfill when performing a PDI or after an oil and filter change.
Typically you will find the dipstick indicates an overfill of 1/2qt of Engine oil.
There is no need to drain the oil at this time, as this concern will not damage the engine nor affect operation.
When it is time for the oil change, fill with the recommended amount of engine oil as specified in SI
SI has been updated with the engine oil (with filter) fill specification of 8 quarts or 7.57 Liters for 5.3L, 6.2L RPO's L83, L86 engines in the models lists above.
Note: The correct "full" mark is the upper dimple and the "add" mark is the lowest bottom dimple on the Engine oil dipstick
