I recently changed over to Valvoline Synpower since I was starting to get more consumption with Pennzoil Platinum. I had always had a little but it seemed to be more than usual so I changed over. I have about 1,200 miles on the SynPower and it was about a 1/4 quart low. Is that within GM's "acceptable" range?
I thought I read somewhere that when changing brands, etc you should run at least two oil changes and that the consumption might settle during the second change. Is there any truth to that? If that is the case then I will stick with the Synpower and change it and see what happens. If there is no truth to that I might try M1 and see if the consumption lessens.
Based on the MDS for Pennzoil, SynPower and M1 the NOACK is all the same at 10 but the M1 Extended Performance is 9.5. Anybody run the M1 Extended Performance and notice any consumption?
I do have AFM turned off as well and have 112K.
Because I haven't seen a poll on this, I added on to the post. If you are running either Pennzoil, Valvoline or M1 and do or don't have any oil consumption issues select the correct one. I don't know how it's going to work but I thought I'd give it a shot.
