2010; 5.3L; 70,000 miles; Crew Cab 4X4; Lifter problem (???)...so the shop says...oil pressure low; stop engine light on along with engine light and oil can lamp...chiming constantly...is this a correct diagnosis?
Is there a "lifter problem" history with these engines? Shop wants $3000 to repair all the lifters.
I am thinking a clogged Valve Lifter Oil Filter or Bad Sensor. I was going to add Marvel's Mystery Oil to the Gas and Oil to see if that clears it up. Too few miles, and normal use...I should not be having this issue.
Input is welcome!
Input is welcome!
