Recently I've noticed an issue with my 07 sierra. It has a 5.3L with 67K on it. After sitting for a while sometimes it hard starts. It doesnt take a lot of cranking, but it starts and the RPMS go high then drop very low then steady out all in about 3 seconds. If it doesnt sit for a few hours and I start it it's fine. Once it's running I don't have any issues. It idles smooth, accelerates and holds speed smooth and no issues with fuel mileage. Today I replaced the plugs and wires and cleaned the MAF and Throttle body to see if that would help at all. I won't know for sure until the truck has sat for a while, but once I got done with all of that I hooked up a fuel pressure gauge. With the key on, but engine off the pressure went up to around 57 psi and over about twenty minutes it dropped to around 45 psi. With the engine running the pressure holds steady at about 62 psi. My question now is do I have a problem and if so what would it be? From what I thought (which is probably wrong) if the fuel pump check valve is bad the pressure should drop pretty quickly, and if the injectors are leaking I would be experiencing other symptoms like rough idle and issues accelerating and at speed. Also if it is an injector issue would I need to replace all injectors or just the faulty one(s). Thanks in advance for any help.
