The fuel tank pressure sensor is the input that can generate this code. The system only conducts this test 1 time during cold starts. The ecm is not seeing the right amount of vacuum during its test. This can be caused by multiple different things. A bad fuel tank pressure sensor, a cracked evap hose, a cracked fuel filler neck. This code can only be generated by the lack of evap system sealing, a lack of vacuum, and the perception of lack of vacuum. Search this #09-06-04-024. You have already hit the most common causes. I hate telling people to waste money but my next move would be a fuel tank pressure sensor If I didn't have a smoke machine to diagnose the actual root cause. hope this helps.
