I have a dual double din in 08 silverado I'm installing with the PAC rp5 gm31 harness and cannot get the steering wheel controls programmed to the dual double din...any suggestions or has anybody else have this problem?
How did you hook the swc controls up to the OGM-1 since that unit doesn't have the 3.5 mm jack either?......and yeah I may look into the idatalink maestro if I can't figure out this pac unitB Cubed said:PAC's product reliability is pretty poor in my book. Back when I had a Pioneer HU in my truck I tried using the RP5 because it combined the steering wheel controls into a single unit as opposed to the PAC OS-4 which required a separate steering wheel interface. When I first connected it I tested all the functions and it worked great. However after I placed the HU and all the wiring back into the dash the steering wheel controls stopped working. Initially I thought maybe I had accidentally unplugged something or possibly pinched a wire. I pulled the HU back out and inspected all the connections and wires and everything checked out fine. A buddy of mine works at a car audio shop and he told me that they have had a lot of issues with PAC and no longer use any of their interfaces on their installs. So I put the OS-4 back in and soon after that I purchased the Advent OGM-1 to replace the Pioneer HU. I haven't used it myself but I've heard that the iDataLink Maestro interface, though a bit on the pricey side, works very well.
The radio instructions showWelcher774 said:Idata maestro is nice came with my alpine x009 head unit. I used the rp5 unit on the alpine 8" I had originally i stalled in my truck. Do you have the instructions?
The OGM-1 doesn't require any interface adapters.nicks93hotrod said:How did you hook the swc controls up to the OGM-1 since that unit doesn't have the 3.5 mm jack either?......and yeah I may look into the idatalink maestro if I can't figure out this pac unit
