Hi all,
One more PCV System question here. In certain drawings of the PCV system for model years 99-06 5.3L's (which may or may not be correct) i see in addition to the PCV orifice on the driver side valve cover and its corresponding tubing to the intake, a secondary, passenger side valve cover PCV orifice (exit?) and it being routed to perhaps the throttle body?
This might be the fresh air part of the system? Or does it even exist? If it does can someone comment on what its use is for, and where the parts are ACTUALLY located, i've looked all over for it along my firewall and valve cover on the passenger side and have found nothing. i do see two tubes on lower under-side of the throttle body, one looks like a air bleed hose from the radiator and something else which i do not recognize (PCV?)
