Yes, I broke 3 of them the last time I changed mine (pulled the boot & connector off of the end).clearlake outdoors said:also some of the plug wires will probably break getting them off, make sure you have wires
What side is the steering wheel on. English truck. Just Kiddingapcnc said:That would be #8 on the passenger side... right? Or if #7... driver side. I am assuming the passenger side, that's about the hardest one on my 11. Its been a while but I think its same one on those years.
Not hard... its pretty straightforward. I would swap it with another first to be sure that is the problem.buduck04 said:How hard is it to replace the actual coil? Still getting a misfire on cylinder 2 after replacing plugs and wires
