Possible BCM Issue?
Tags
solved
4.2K views 7 replies 5 participants last post by  gripwitmer
gmt900 trucks I don't believe you can swap bcm's like you could with gmt800's, they are more vin locked.
I would suggest :
-get codes for what is happening for the ecm
-make sure the security system is happy (there should be a chip in the ignition key, which the security module reads, and communicates w the ecm to allow starting)
-work through the no-start diagnostic procedure on charm .li for your truck.
