I have a 2008 GMC 5.3 flex fuel with 101,618 miles. Running a diablo intune on it. Currently I have the AFM turned off and I am running the MPG booster canned tune. I was running the canned 87 octane tune but switched to the MPG booster a little but ago. I've only ever put 87 octane unleaded fuel in the truck
Had my truck serviced today, front differential, rear differential, transfer case fluids replaced, dropped transmission pan and filter, and replaced plugs and wires. Replaced plugs with AC-Delco 41-110 and Napa Belden premium wires. Got it all done for $360.
Mechanic took it for a test drive, tested it pretty hard and said he heard a preignition tap/knock. I've never heard of it nor heard a knocking before. Mechanic said it is hard to hear. He mentioned that unless I am driving the truck hard or under heavy load, the preignition knock should not be an issue. I rarely tow and I don't drive the truck hard.
He did recommend using 93 octane fuel if I am running any tune on the motor. He also said to run a data log with the intune and if there is a data point that lists KR or knock, if it is bouncing around then I have an issue. I am not too inclined on the intune beyond AFM delete and canned tunes so I don't know how to review the logs.
So I ask, what is a preigintion knock as google wasn't too helpful in explaining it and providing examples of what it sounds like.
Do I have an issue I need to address or am I fine?
Any information and advice is most appreciated.
