The TICK, the CHIRP, misfire on cylinder 1, and random misfire. Wholly crap . Yes i have gone through the post on the tick.
So the tick is likely the lifters and probable worn cam. new cam lifters and cam would fix that part. The chirp sounds like dry cam bearings and or really worn cam bearings. The misfire on cyl. 1 was a P0301. I checked injector harness with noid lite. O.K. the swapped out coil with #2. o.k. there. Then checked plug. Clean white . O.K.. then checked spark plug wires . O.K. What i'm thinkin is cam worn down quite alot on #1. Being if its a worn cam . Most likely will not easily slide through the cam bearings . Also noticed my oil pressure has always been around 35 to 40 psi. since the misfire this morning its at 80 or pegged out max.
If some of you think this sounds about right in a nut shell let me know.
The repairs needed . Melling oil pump, pan gasket. head gasket intake gasket, lifters ,cam cam bearings timing chain , chain guides and timeing chain tensioner. My vehicles are 4 down. 2005 Triumph needs tires and brake rotor, My 05 gmc ticks , my 2006 pontiac G6 has evap issues, My 1980 mercedes diesel needs timing chain . To many problems. Please help my Gmc.
Thanks for listening . Just venting. Quinn
