I found a pretty good sized scratch on my truck the other day on the lower part of the front fender. I've filled it with a little touch-up paint to keep it from rusting until I can really work on it.
From what I've found online I have two options. 1.) Fill the scratch with a spot putty and then cover that with touch-up paint. 2.) Fill with touch-up paint and let dry, wet sand with 2500 grit and then compound/polish to remove scratches. By using 2500 grit the scratches should be fine enough that Meguiar's Ultimate Compound and Polish should remove them fairly easily, right? I'd tape off the scratch so I don't sand more of the body panel than I need to.
The scratch is about an inch long.
