I bought a 2000 chevy silverado as a fixer upper. First i had brake issues and finally got those all fixed and now I'm on to the service 4wd message. The truck is throwing code C0327 encoder motor circuit malfunction and was throwing a code for an open ground, found a broken wire creating a bad ground and fixed it plus cleaned the ground points. I am at a loss with this issue though and can't get it figured out.
What I've done/what the PO replaced:
-new TCCM
-new selector switch
-new encoder motor
-new front axle actuator
-ground points cleaned
-fuses are good
-tested for voltage at the encoder motor and have 11.7 volts to the orange fused wire and 4.83 to the red and black wires
-tried unhooking the battery for a week for a hard reset on the tccm to no avail
Any help is appreciated! Thanks
-new TCCM
-new encoder motor
-fuses are good
