SgtShiv's 2015 Sonoma Red Sierra
11K views 94 replies 20 participants last post by  SgtShiv
#1 · (Edited by Moderator)
Bought a 2015 GMC 1500 4x4 with a 4.3 in early June. So far I have removed the front air dam, added a TruXedo Lo-Pro QT tonneau cover, AVS vent visors and a 2.5 RC leveling kit. Zone 1.5bl, Airraid MIT with AEM Dryflow filter ordered and should be arriving any day now. More mods to come as I continue to plan and research the direction I want to go.
#78 ·
Funny how things change once they are installed. I liked the look of the ICI Magnum step bars when I was looking at them on line, then they arrived in the box...wasn't quite what I expected but then I put them on the truck and then I knew I made the right choice.
#81 · (Edited by Moderator)
Tear down for fog light install.
Inner bumper bracket that needed to be removed to allow access to remove filler pieces and install fog light assemblies.
After bracket is removed easy access.
New assembly and hardware installed.
All assembled.
#82 · (Edited by Moderator)
Fog lights only.
Headlights only.
Headlights and fog lights.
Led light bar only.
All on.
Parked about 30 feet from the garage. Still need to adjust the fog lights a little I think, but I'll mess with that another night.
#84 ·
Wow nice job Shivs!! I like the fact you took the time to do the fog light set up...Makes a huge difference..you'll never use your high beams again. Well with light bar you wouldn't anyways!! What size light bar? A 32 inch was the biggest I wanted to go (plus it was cheap lol) as I figured it would be the only one that would fit, but yours looks a little wider. What LED fogs did you go with? Now you need to do those headlights, I went HID ,and in the projectors, they are fantastic. Crisp clean and very bright!
Preview of gallery image.
#85 ·
Good looking truck you have there!
#86 ·
Malaki said:
Looks awesome! You wont have any problems not seeing at night
Thank you sir and should be a lot better then when stock.
Thanks and yes made a huge difference. I rarely get to use my high beams anyways with oncoming traffic. Light bar is 32" Opt7, the fog lights were Morimoto XB LEDs. Have a set of Morimoto HIDs on order just waiting for delivery. Your setup definitely looks good, has to be a huge difference at night.
Thanks man I appreciate that.
