While searching for a constant power I accidentally shorted it out and not everything is messed up. I shorted the pink hot wire running to the turn signal fuse in the front fuse panel. Doing this I lost turn signals. When I turn on a signal I lose dash lights. I press the emergency blinkers and dash lights turn on and off, unless the turn signal is on. I also have zero cab lights and hitting the breaks with the emergency flashers on, the direction that makes me have dash lights, my dash lights go out. I also have zero reverse lights. I replaced the turn signal flasher and no help. And advice or speculation would be appreciated.
