I was advised to do so when I got the truck. But I also read that you needn’t do that on fuel injection cars and trucks. What would y’all recommend I do?
Right on!Some service facilities used to recommend turning the AC off before starting the engine back in the day - like pre-1990 in order to minimize engine drag. Also, so many cars were way out of tune that they needed all the help they could get in order to start (and keep running).
It is not necessary to do so today because the ECM & BCM will not send an on command to the AC compressor clutch until after the engine has started.
Remote start does not seem to engage climate control all of the time. I've wondered why sometimes it does, sometimes it does not.set my AC on max so I can remote start and have it be cool
On my old truck, I have no climate control like modern trucks. Just two sliders...one for each side, but the concept of zoned air inside a car is a bit dumb...I guess good if you want a specific air blown on you, which would cause others who want the opposite to the opposite, start an air war...lolRemote start does not seem to engage climate control all of the time. I've wondered why sometimes it does, sometimes it does not.
An '08 Subaru used to make gear-on-gear noises when starting with AC on, so I got in the habit of leaving CC off when parking the vehicles. Radio is off because it is never on. And especially making sure wipers were off.
Don't'cha hate wipers running across a dry windshield when starting up![]()
A remote start unit is supposed to be connected to the AC MAX wire- if the connections were made using Scotch Loks, it's possible that it's not making a good connection.Remote start does not seem to engage climate control all of the time. I've wondered why sometimes it does, sometimes it does not.
When your engine is cranking, loads such as the a/c are not getting power. They will not get power until the key is returned to the on position. So you are not loading up the battery while cranking. No reason to turn the a/c off.I always try to turn off all accessories before cranking over an engine. No reason to load up the battery, it's a good practice. Plus, I don't think I've turned on the AC yet this year, I usually run with the radio off and windows cracked open. I just did 4 hours of driving yesterday to the beach for the boat races and then back home, no AC needed with the windows open and fan turned on.
