1 - 2 of 2 Posts
Sierra
This truck is a 2011 Sierra sle 6.2 w 86k miles
Asking $29k obo
****accident free*****
*diablew tune (tuner comes with it)
*Max liner floor liners
*Tyger tri fold bed cover
*Tyger running boards
*Spray in bed liner.
*Back up camera
*Carbon window tint
*Aem dry flow filter
*Has cabin air filter (not all do)
*gibson muffler(sounds good, no drone towing)
*fitted mud flaps
*Rancho 7k shocks/struts
*Cold case aluminum radiator
*Tru cool 40k trans cooler
*Derale 180degree thermostat for trans cooler, All hard lines with oem push lock connections No rubber hose to fail.
*nkg plugs and ac delco wires at 80k
*Transmission filter, fluid, and transfer case fluid at 72k
*Power stop drilled& slotted rotors -w- z36 towing pads. Brake fluid flushed with dot 4. 2/21
*Deegan 38 a/t tires 1/[email protected] 82k
*Duracell battery 3/[email protected] 84k
Truck is a 6.2 4x4 sle crew cab with 3.73 gears. Has the nht/max tow package and no displacement on demand to cause problems. (Only motor not to have it) All cooling components have been over built to insure trouble free camping trips with our small camper. Maintenance is always done on time and has been a well cared for truck, waxed twice a year. Truck has a 2in lift in the front and 3 in block in the back to get it up just a bit. Comes with the factory rear blocks if you prefer the "leveled" look. Passenger air bag recall completed as well. Title in hand
Discussion Starter · #2 ·
Lock it up, sold
1 - 2 of 2 Posts
