Spin on Filter drip
278 views 12 replies 6 participants last post by  Paulbreitag
On my 2005 Silverado, the Alison spin- on filter is dripping. I replaced the old filter because it started to drip. Thinking a new one would remedy the problem I changed it to an OEM Alison filter. It is still dripping. Has anyone had that same issue, and if so, how did you fix it?
Did you do anything besides remove the old filter and install the new one, like check if the center fitting was still tight and undamaged, that the mating surface was nice and clean and didn't have an old gasket stuck to it, or even that the trans fluid wasn't coming from someplace nearby?
Check to make sure there are no gouges or starches on the mating surface. That will cause it to leak. Also, in my experience, the Allison filters like to be out on a little tighter than say a oil filter. I usually get them fairly tight by hand. Beyond what is marked on the filter. Obviously don’t crank it down and fully compress the seal, but try going a little more with it and the standard.
