Has anyone else been having problems with the low beam headlights lasting 1 to 3 months? I have a 2011 Silverado and believe is the same bulbs for 2007 to 2013. I don't know if its my truck or am I just having bad luck bulbs. I was using Sylvania silverstars but those would last me about a month and then burn out. I contacted the company and of course wouldn't do anything blamed it on a problem with my truck... I then switched to PIAA cheap bulbs and they lasted me about 3 months. I had HIDs in there at one point and was having problems with the ballast box in there going out. I don't really want to use those again. Am I better off just switching to LED and if so which ones are the best option to choose from?
Also another thing that I have noticed is my headlights dim down a little when coming to a stop or turning. When I initially apply the brakes they dim and then go right back to normal. I have had the charging system and battery tested and everything comes back good. Just one of those annoying little quirks.
