The secret to keeping the interior of your Sierra clean
391 Views 11 Replies 4 Participants Last post by  davester3500
12
Lasfit has achieved innovative breakthroughs in materials, craftsmanship, and design, making the floor mats an excellent companion for the GMC Sierra 1500/2500/3500. They not only protect factory floors but also have many advantages such as beauty ,easy cleaning, and tight fit.
1、What do you concern about when choosing floor mats?
Lasfit floor mats are made of TPE which is an environmentally friendly material free of notorious offenders. TPE is a Thermoplastic Elastomers, Combines the advantages of rubber and plastic materials, so it has good resilience, durability, and flexibility. TPE is a kind of odorless, harmless, environmental, and durable material. This not only means that floor mats can adapt to all weather conditions, but also take responsibility for the driver's health.
Lasfit uses as injection molding process that allows for a flexible and soft material. This process provides a rugged durability and excellent grip for those wet, muddy, and snowy days. The TPE material prevents the mats from cracking, curling, or hardening on the hottest and coldest of days. Lasfit designed the plug hole which is firm and flexible, working with the factory fasteners, which prevents the mats slide around underfoot. The anti-shift lines on the back of the mats grip the carpet and help hold the floor mats in place.
We used Injection Molding Systems and 3D real vehicle scanning technology to capture every corner and crevice that fits Sierra 1500 Crew Cab perfectly edge to edge. Our floor liners guarantee maximum coverage and use factory retention devices to keep your liners securely placed so they protect your factory floors and resale value.
When excellent materials, superb technology, and meticulous design come together, they present an astonishing fit during the mat's use. As shown in the real shot below, you can see the floor mats fitting snugly on the floor, clean and elegant.
2、Choose the correct floor mats for your truck!
1.Crew Cab Only
Sierra 1500/2500/3500 has three models, Crew Cab、Double Cab and Regular Cab. Lasfit designed its floor mats specifically for the crew cab version(4 full size doors) of 2019-2023 Sierra 1500 and 2020-2023 Sierra 2500/3500.
2.Bucket Style Only
This floor mats fit for bucket style, but don't fit for bench style(there will be a missing piece in the middle of bench seating). You need to choose the appropriate type to get the optimal experience.
3.Carpet Storage Style Only
This floor mats are compatible with the Sierra 1500 with Factory Original Carpeted Under-Seat Storage, so they don’t fit for with plastic storage or without storage. Difference type of storage boxes occupy different space, which means the design of floor mats must be adjusted accordingly.
You also need to carefully compare the demonstration pictures below to confirm that you will purchased the correct storage style.
3、How the Floor Mats Look Like in Sierra 1500?
What concerns you most when you're looking for Sierra 1500 floor mats?
We're looking forward to your real thoughts, please feel free leave messages below or email/PM us!
Click Lasifit floor mats, if you want to learn more details about these floor mats.
See less See more
  • Wow
Reactions: 4
1 - 12 of 12 Posts
...note, they only hae stuff for the very latest model trucks, like around '20/'21 or newer...at least so far...
I want something like this for an older extended cab with vinyl floors, I like that little thing that holds it in place. Been looking for a good set.
I got some Huskee (Husky?) ones for my '04 and '12, the '04 ones work pretty well at holding all the snow and crap that get tracked into the cab during the winter.
Do they have something like the lasfit have to hold them down? My problem is they like to slide around on the vinyl floors.
I have the weather tech and love them but husky is good to lasfit makes good bulbs we will see liners look cool have seen them on lone star Hawaiians trail boss
Yes they come with a retaining clip, but I haven't used them. For my '04, it's on carpet, for the '12 it's on vinyl, and neither slide around on me. The ones in my '12 are more closely formed to the truck, including a lip that goes along the sill, so it's held in place well enough for me.
I was just looking at those husky floor liners, it says on the website that they dont accommodate for a manual shift transfer case. Does your truck have a manual shift 4x4? Do the liners still fit nice?
Thank you for your feedback! Unfortunately, we currently only develop floor mats for the 2019-23 Sierra, but we have LED bulbs that are compatible with your 2004 Sierra.
High Beam: LAplus series 9005
Low Beam: LAplus series 9006
Fog Light: LAplus series H10
License Plate Light: L-T10
Back Up Light: L-3157
Center High Mount Stop Light: L-T15
If you have any other needs, you can click Lasfit.com to enter our official website for purchase. We hope to meet your needs!
Well then, I'll certainly consider replacing my floor matts with your LEDs when they next need replacing..
Reactions: 1
Both my trucks have manual shift. It slightly pushes the liners over a bit, you can trim the edge of the liner to go around it if you want. When I bought the '04, the p.o. has husky matts covering everything, which didn't work as good because they didn't hold much water, but I still use the center piece, over the hump. It had molded lines on it, for where to cut to go around the manual shift plate, and when I upgraded the truck to 4wd, I just cut out that section and it fit perfectly around the shifter.
Reactions: 1
1 - 12 of 12 Posts
