1 - 5 of 5 Posts
The torsion bar bolt backed out on the passenger side of my 03 Silverado. I was walking out of the backyard and as I came up to the truck it looked like one side was lower than the other. I was going over to the shop anyway so I put the truck on the lift and after looking at the springs I looked at the adjusting bolts,the passenger side was just about out. WTF? So now the torsion bars are out of adjustment. I tried to turn it back in to the same measurement as the other side, but now I am a inch off from side to side and the rear is off the the same. I guess I have to fool with it some more. Any procedure to follow ajust them? Then some blue Loctite.
2009 Silverado LT 4WD
Just run it in some more until it's close or a little higher by eye, then take some measurements while off lift , take it for a little drive to settle suspension. Take more measurements and readjust as necessary..
Thanks for the reply, I figured that it would be trial and error before I can get it adjusted right again.
1 - 5 of 5 Posts
