GM says that the 2-3 flare is 'normal'. My '13 does it, too.
Document ID: 4597361
Some customers may comment on a 2-3 upshift slip or flare.
This condition is a NORMAL characteristic of the transmission
and will not cause durability concerns and no repair attempts should
be made.
Service Procedure
At this time this flare condition has been recognized in two different driving conditions:
1. During the first 2-3 upshift after the vehicle has been sitting, engine off for several hours. This
condition may be caused by air that is trapped in the 3-S-R clutch assembly.
When the first 2-3 upshift is made this trapped air is purged and the following 2-3 shifts will
be normal with no flare.
When diagnosing this condition, a garage shift into reverse before drive will purge this air and
prevent the 2-3 flare from occurring. This condition is a NORMAL characteristic of the
transmission, it will not cause durability concerns and no repair attempts should be made.
2. When transmission ATF temperature is at or below 85 degrees F (30 degrees C). This 2-3
upshift flare can occur until the ATF temperature warms. If the 2-3 flare is determined to be
ATF temperature sensitive use a Tech 2 to make note of the throttle position when the flare
occurs. Drive the vehicle to get ATF temperature to at least 104 degrees F (40 degrees C) and
then make several 2-3 shifts at the throttle position determined to be the most sensitive to
the 2-3 flare, This will allow the transmission adapts to tailor the shifts and may help to
eliminate the cold 2-3 flare. This condition is a NORMAL characteristic of the transmission, it
