1 - 8 of 8 Posts
My 2015 2500hd 6.0 gas is throwing u0140, u0101 and a u0102 codes now I disconnect the battery it turns of for about 30 miles then comes back not sure if it has something to do with the power chip that I recently removed from the truck or if it is something else any help would be appreciated thanks
2015 High Country Duramax
Those are all communication codes. Meaning that the controllers, which in this case is the BCM, TCM, and TCCM, aren't communicating on the data network.
What kind of "chip" was it, and how/where was it installed? And did it start as soon as you removed it? Any other work done to the truck lately?
2012 Silverado 2500HD 4x4
Google the codes,, I do not have my scanner book with codes now but I know you can fund them online!
It was a bully dog tuner you plug in the obd2 and I went to advanced to get a battery and he just unplugged it to put his charger on and when I went to reinstall the tune it froze up so thinking something is screwed up with the computer maybe?
Maybe next time start with that! You are going to have to reinstall your tune or the factory tune. Either way it sounds like you need to get ahold of Bully Dog.
Discussion Starter · #8 ·
Started to reinstall the bully dog and it said restore to factor then reinstall so I did that and then reinstalled it and so far so good after 100 miles.
1 - 8 of 8 Posts
